[Qgis-user] Fields Text Edit widget "HTML" option: How is it supposed to work?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sun May 31 11:14:06 PDT 2015
in my search for means to create more complex labelling, I stumbled upon
the option for the Text Edit widget to check "Multiline" which enables a
"HTML" checkbox.
As I only find zero description on that feature, I wonder what it is good
for, cause using it only yields strange results:
Editing an entry of my text field does not replace the NULL, but the NULL
is shifted right when typing.
Stopping the edit with return, the typed text disappears again and NULL
remains.
However, using the field calculator to populate the field works. Inserting
'<i>hello</i>' into my label field shows only <i>hello</i> on the map, and
not an italic text.
Interestingly, when I now click once into the field with <i>hello</i> in
the attribute table, my "hello" is displayed italic, but leaving the cell
resets the content to NULL again.
So, is this all only nonsense, or is there sth wrong with my install or
this a bug?
Using 2.8.2 on Linux Mint 17.
Cheers
Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
