[Qgis-user] Ho retrieve the attributealias list
Andrea Peri aperi2007 at gmail.com
Mon Nov 2 12:11:30 PST 2015
I resolved !
The solution was:
                for idx, fld in enumerate(layer.dataProvider().fields()):
and after in the code retrieve the alias (or the fieldname) using:
                layer.attributeDisplayName(idx)
and the real name of the field using:
                fld.name()
Thx for help.
2015-11-02 16:32 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> yes , my goal was to retrieve the aliases.
> To reach this information I plan to use this function:
>             fldDescr = fld.attributeDisplayName()
> The attributeAlias give me the aliases when availables, but when they
> are not filled it return a null (or empty) string.
> Instead the attributeDisplayName() return the Alias or the original FieldName.
> A.
> 2015-11-02 15:28 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
>> Hi
>> layer.attributeList() works for me, I really don't know what goes wrong
>> there for you. But it's a quite silly functions since the attribute
>> indexes were changed to always be sequential. Now it just delivers a
>> list each numbers from 0..count-1. So your enumerate will allways give
>> you [(0,0)..(n-1, n-1)].
>> That said, what you probably want to use is layer.attributeAliases().
>> That gives you a mapping of field names to aliases.
>> Or [(idx, layer.attributeAlias(idx)) for idx in
>> range(layer.fields().count())] if you really want to use the field indexes.
>> Best,
>> Matthias
>> On 11/02/2015 02:28 PM, Andrea Peri wrote:
>>> Hi,
>>> I need to retrieve a list of attribute alias.
>>> To do this, I try this code:
>>> for lid, orientation in self.templateTable.model().getObjectIter():
>>>    layer = QgsMapLayerRegistry.instance().mapLayer(lid)
>>>        for idx, fld in enumerate(layer.attributeList()):
>>> The qgis report me this error:
>>> AttributeError: 'QgsVectorLayer' object has no attribute 'attributeList'
>>> But I see the AttributeList is available in that clas as reported from the
>>> help.
>>> http://www.qgis.org/api/classQgsVectorLayer.html#a9fdee4a58551d7e1424c8f66ab6c14a0
>>> Perhaps I'm wrong something or the documentation API is obsolete ?
>>> Thx.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
