[Qgis-user] QGIS supported server OS and System requirement
Neumann, Andreas a.neumann at carto.net
Tue Nov 3 03:15:18 PST 2015
Hi Sushim,
Most QGIS Server users are on Linux. Windows users complained a lot -
but theoretically it should also work on Windows. I use Ubuntu Server
LTS (14.04). You could also choose Debian, Fedora or SuSE. All of these
have reasonable amounts of users.
I usually compile QGIS server from source - as this is quite flexible if
you need a new feature and don't want to wait for a release.
Compiling QGIS from source is probably also easier on Linux.
As to hardware: I don't think we can to meaningful recommendations here.
If money is not an issue, I would go with SSD disks. Since QGIS server
is not multi-threaded, faster CPUs are more important than many cores.
Memory wise I would go with 24+ GB - but it would also work with less.
Hope this helps,
Andreas
On 2015-11-03 11:31, Sushim Giridhar Bhiwapurkar wrote:
> Hi Everyone,
> We are setting up a server where we would like to install QGIS 2.8. We would like to know about the server operating system that QGIS supports and the system requirement (server hardware) to manage 10 concurrent users.
> Your inputs will be helpful for me to finalize the server and OS. We are open to use any OS like Windows / Linux / Mac etc.
> Please also suggest some links if there is any information available online related to my query.
> Regards,
> SUSHIM
> Disclaimer: This message and the information contained herein is proprietary and confidential and subject to the Tech Mahindra policy statement, you may review the policy at http://www.techmahindra.com/Disclaimer.html externally http://tim.techmahindra.com/tim/disclaimer.html internally within TechMahindra.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151103/72ef5fd5/attachment.html>
