[Qgis-user] How to convert a QGIS project to a web hosted version
Uros Preloznik
uros00 at gmail.com
Sat Nov 7 01:47:25 PST 2015
If you have access to server and want to try on your own you can check out
Extended QGIS Web Client.
https://github.com/uprel/gisapp
There is also "official" QWC and LizMap:
https://github.com/qgis/QGIS-Web-Client
https://github.com/3liz/lizmap-web-client/
LizMap also has a QGIS plugin to setup web related stuff in QGIS project.
All these are specially designed for hosting QGIS projects on your own and
also have documentation how to start.
regards,
Uros Preloznik
http://level2.si/
2015-11-05 18:25 GMT+01:00 Piotr Kania <p.kania at op.pl>:
> Hi!
> If you don't have time take a look at qgiscloud.com
> Here:
> http://qgiscloud.com/oper4/tax_krakow_qgiscloud2
> is example - it looks exactly as my qgs project (group "postgis"- all
> vector layers, "MAPA TOPOGRAFICZNA" and others - wms). The only limit is
> that you can't have your local rasters, only wms. But good thing is all
> settings from your local qgs project are in that web map - for example in
> my qgs project wms layer "Dynamiczna hipsometria" (in English - dynamic
> hipsometry) has transparency 50% - as it comes from the same lidar data as
> wms layer "ISOK_Cien".
> Here are others links:
> wms:
> http://wms.qgiscloud.com/oper4/tax_krakow_qgiscloud2
> mobile version:
> http://m.qgiscloud.com/oper4/tax_krakow_qgiscloud2
> W dniu 2015-11-05 o 17:46, Jesse McGraw pisze:
> All,
>> I've got a couple of personal QGIS projects that I was thinking it
>> would be fun to make available via the web and I'm not quite sure where to
>> start.
>> Can anyone point me to a good from-scratch guide on how to do this? I
>> could also use some suggestions on hosting as I've never tried this
>> before. Apologies if I'm asking a question that's been well covered
>> already.
>> If you're curious, the projects are on github:
>> https://github.com/jlmcgraw/aviationMap
>> https://github.com/jlmcgraw/natural_amenities
>> Thanks,
>> Jesse
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151107/6316c472/attachment.html>
