[Qgis-user] Set default view for Identify window?
Andrew Harfoot ajph at geodata.soton.ac.uk
Mon Nov 9 04:58:45 PST 2015
Hi Robin,
Have you tried using the Value tool plugin as an alternative? I think it
predated the addition of the raster specific elements to the core
Identify tool, and offers greater functionality. I particularly like it
as it is a separate panel, not tied to the identify tool, without adding
another button. It also offers multi layer views and customisable band
combinations. NoData values are shown as zero - which may or may not be
an improvement, but as it's Python based, you may have more luck
customising it.
Cheers,
Andy
On 20/10/2015 19:14, Robin Wilson wrote:
> On 20 Oct 2015, at 12:14, Nathan Woodrow <madmanwoo at gmail.com
> <mailto:madmanwoo at gmail.com>> wrote:
>> I'm keen to kill that dock and replace it with something better in
>> the next version or version after.  Open to ideas on that.
> Did you have any specific ideas yourself?
> I'm keen to see it work as well as possible - it's one of the bits of
> QGIS that I use the most (I write most of my analysis code in separate
> standalone Python scripts, and then use QGIS for investigating and
> visualising the output). The table and graph views are great - but
> possibly need a bit of work (eg. I opened a bug report on an issue
> with the graph and NaN values in bands - see
> https://hub.qgis.org/issues/13639). I still far prefer it to the
> equivalent windows in other tools (ArcGIS, for instance).
> Robin
> Qgis-user mailing list
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel:  +44 (0)23 8059 2719
Fax:  +44 (0)23 8059 2849
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151109/b65e2eab/attachment.html>
