[Qgis-user] columns in spatialite
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Nov 12 08:34:18 PST 2015
Am 12.11.2015, 16:17 Uhr, schrieb Paulo van Breugel
<p.vanbreugel at gmail.com>:
> On Thu, Nov 12, 2015 at 3:48 PM, Neumann, Andreas <a.neumann at carto.net>
> wrote:
>> I believe the main difference between SpatiaLite and Geopackage is that
>> a SpatiaLite database contains a lot of query functionality >>and
>> additional data (e.g. a big list of CRS) - while Geopackage does not
> That would be a very big list of CRS, or does the query functionality
> take that much space? I often used spatialite, but given >that I
> normally use it to store many layers, I had actually never noticed the
> large initial size. This is imho indeed a clear >disadvantage when used
> for data sharing.
>> When you checked filesizes for shp: did you only look at the shp, or
>> also include dbf, shx, prj, etc.? Otherwise you comparing a >>complete
>> dataset with attributes and metadata against just geometry.
> All files, not only the *.shp file. I just created a simple vector layer
> in QGIS and saved it as shapefile, geopackage and >spatialite file.
Seems I'm a bit confused by the differences between spatialite and sqlite.
A spatialite db is always 4 MB + x which makes a huge difference for small
layers, but I guess the differences become closer when having "normal"
sized layers.
What is irritating me is, when I use a small layer and perform some
processing function and then save it as .sqlite to a file, the result is
only a few kb and not 4 MB.
So, having sqlite as default temporary output in processing would not make
any difference to ESRI shape sizewise!
Example: a shapefile point layer with quite some attributes and 999
features has 4.4 MB
saving this as spatialiate: 4.6 MB
saving as sqlite: 86 kB !
The sqlite file is 5 times smaller than the ESRI shape file while the
spatialite file is about the same as the shape.
Here on 2.8.3 at the office I have no geopackage option to test with.
So, whats the difference between sqlite and spatialite in detail?
Cheers
Bernd
>>>> Andreas
>> On 2015-11-12 15:36, Paulo van Breugel wrote:
>>> On Thu, Nov 12, 2015 at 1:30 PM, Matthias Kuhn <matthias at opengis.ch>
>>> wrote:
>>>> The main issues with spatialite are IMO: It's based on sqlite so
>>>> deleting columns and renaming columns is not supported by design. We
>>>> could offer some hacks to bypass this (annoying restriction) from the
>>>> UI
>>>> - there is a risk of side effects though. Another property of it is,
>>>> that it's already 4-5MB big, even when empty. I consider this a major
>>>> limiting factor as well. Other issues which we were not yet able to
>>>> solve are its management of the information scheme which keep
>>>> duplicate
>>>> entries of tables and columns which need to be properly updated which
>>>> we
>>>> apparently do not manage (yet).
>>>> Geopackage is also based on sqlite, so the column delete/rename
>>>> restrictions apply as well (with the same workaround possibilities). I
>>>> haven't checked the file size, but if that's smaller, that would be
>>>> quite nice (does somebody know?).
>>>Just checked saving a shapefile of 941 bytes as Spatialite and
>>> Geopackage file. The first is indeed 4.4MB. The Geopackage is
>>> >>>12.3kB, i.e., larger then the shapefile, but the increase is small
>>> compared to the spatialite file. I am not familiar with the
>>> >>>differences, but this makes the Geopackage a better candidate imho.
>>>> All the best
>>>> Matthias
>>>>>> _______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Erstellt mit Operas E-Mail-Modul: http://www.opera.com/mail/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151112/118962bc/attachment.html>
