[Qgis-user] Creating Geometries for tabular data
Randal Hale
rjhale at northrivergeographic.com
Sun Nov 15 15:36:34 PST 2015
Probably the easiest way to do this would be a join - so if you made me
do this I would do:
1. Create a layer (say a shapefile) with a point and a unique ID.
2. Make sure that Unique ID is reflected in your tabular data (point 1
has a corresponding '1' in the tabular data or a point of "Water Park"
has a "Water Park" in your table)
3. Right click on your shapefile with the points (or polygons) and go to
properties -> Joins. Pick your two fields that are the same - and join
them.
After a successful join right click and "save as" and make a new
shapefile/Spatialite layer with all of your attributes.
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
On 11/15/2015 06:22 PM, Martin Bain wrote:
> Hi,
> I’m after your suggestions for the best work flow for adding spatial
> data to existing tabular data.
> Say we have a tabular list of playground equipment – I want to
> associate a point object with each row in the list – so I end up with
> spatial and attribute data in the one table.
> I used to do this in MapInfo, you could open a table of purely tabular
> data, select a row in the attribute table, adding a point in the map
> window would create a map object for the selected row (rather than
> adding a whole new row to the table). I don’t think I can do it like
> that with QGIS – am I right in thinking if there is no geometry for a
> row it will be excluded from the attribute table?
> How do people do this in QGIS?
> Thanks,
> Martin.
> This email is intended for the named recipient only. The information
> it contains may be confidential. If you are not the intended recipient
> you must not reproduce or distribute any part of this email, disclose
> its contents to any other party or take any action in reliance on it.
> If you have received this email in error, please contact the sender
> immediately and delete the message.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151115/b7827570/attachment.html>
