[Qgis-user] Problems with Plugins
John Layt jlayt at kde.org
Mon Nov 16 00:47:36 PST 2015
On 16 November 2015 at 08:29, Luigi Pirelli <luipir at gmail.com> wrote:
> if not, probably you are using a Processing master version
> (show_message_log was added in processing 24 days ago:
> https://github.com/qgis/QGIS/blob/master/python/utils.py#L108) and the
> problem can be solved upgrading/downgrading Processign to a version
> compatible with your qgis.
I'm running QGIS 2.8 LTS and this morning I was notified of an update for
Processing plugin, which is now unable to load due to not finding
show_message_log. If it's not compatible with the LTS version then surely
it shouldn't have been rolled out in the main repo with a minimum version
allowing it to be installed on LTS? I can roll it back manually to an
earlier version that does work, but it's not something we should be asking
of general users.
John.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/f844eff9/attachment.html>
