[Qgis-user] Problems with Plugins
Luigi Pirelli
luipir at gmail.com
Mon Nov 16 01:23:13 PST 2015
2.12 works on qgis master... probably victor forgot to set minimal
compatible version in processing plugin metadata.txt
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 16 November 2015 at 10:20, Luigi Pirelli <luipir at gmail.com> wrote:
> hi Marta
> temporarly do this
> remove <your home path>/.qgis2/python/plugins/processing directory
> in this way you'll use the processing distributed with your qgis installed
> version (that I suppose is a stable version)
> every time will be asked you to upgrade Processing (in LTR the distributed
> version is 2.6 and ask to upgrade to 2.12)... don't upgrade! until the
> problem is resolved.
> regards
> Luigi Pirelli
> * Mastering QGIS:
> On 16 November 2015 at 03:19, Marta Modolo <marta.modolo at gmail.com> wrote:
>> Hi to everybody,
>> I contact you because i've got some problem with these plugins: Profile
>> from points, Buffer by Percentage, clip multiple layers, dissolve with
>> stats, multi-distante buffer and Processing. When I open QGis the program
>> say me that: *Questo plugin รจ corrotto*
>> cannot import name show_message_log
>> Can you help me please?
>> Thank you in advance
>> Marta
>> Marta Modolo
>> PhD candidate in Cuaternario y Prehistoria
>> Universitat Rovira i Virgili
>> Avinguda Catalunya, 35
>> 43002 Tarragona (Spain)
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/38738099/attachment.html>
