[Qgis-user] Problems with Plugins
Alexander Bruy
alexander.bruy at gmail.com
Mon Nov 16 01:51:08 PST 2015
Plugin package now updated
2015-11-16 11:44 GMT+02:00 Luigi Pirelli <luipir at gmail.com>:
> I filed the issue... Alex Bruy will be in charge to update the plugin with
> the correct metadata.txt
> https://hub.qgis.org/issues/13837
> in this thread I'll notify when the update will be available... in the
> meantime please remvoe .qgis/python/plugins/processing if your qgis version
> is less that 2.12
> regards
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 16 November 2015 at 10:23, Luigi Pirelli <luipir at gmail.com> wrote:
>> 2.12 works on qgis master... probably victor forgot to set minimal
>> compatible version in processing plugin metadata.txt
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 16 November 2015 at 10:20, Luigi Pirelli <luipir at gmail.com> wrote:
>>> hi Marta
>>> temporarly do this
>>> remove <your home path>/.qgis2/python/plugins/processing directory
>>> in this way you'll use the processing distributed with your qgis
>>> installed version (that I suppose is a stable version)
>>> every time will be asked you to upgrade Processing (in LTR the
>>> distributed version is 2.6 and ask to upgrade to 2.12)... don't upgrade!
>>> until the problem is resolved.
>>> regards
>>> Luigi Pirelli
>>> * Mastering QGIS:
>>> On 16 November 2015 at 03:19, Marta Modolo <marta.modolo at gmail.com>
>>> wrote:
>>>> Hi to everybody,
>>>> I contact you because i've got some problem with these plugins: Profile
>>>> from points, Buffer by Percentage, clip multiple layers, dissolve with
>>>> stats, multi-distante buffer and Processing. When I open QGis the program
>>>> say me that: *Questo plugin รจ corrotto*
>>>> cannot import name show_message_log
>>>> Can you help me please?
>>>> Thank you in advance
>>>> Marta
>>>> Marta Modolo
>>>> PhD candidate in Cuaternario y Prehistoria
>>>> Universitat Rovira i Virgili
>>>> Avinguda Catalunya, 35
>>>> 43002 Tarragona (Spain)
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/d08ad8e0/attachment.html>
