[Qgis-user] Error updating Processing module - No fusion.dtm2ascii module installed
Victor Olaya
volayaf at gmail.com
Mon Nov 16 05:02:31 PST 2015
It seems the problem is in the Processing lidar module. I have
commited a small change that should fix it. We will be releasing a new
version today to fix that.
Thanks
2015-11-16 13:54 GMT+01:00 Elstermann, Mike <Mike.Elstermann at itc-halle.de>:
> Dear list,
> affected also these plugin:
> · Processing
> · Concave Hull
> Some ideas?
> THX, mikeE. the geoObserver
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Alejo C.S.
> Gesendet: Montag, 16. November 2015 13:41
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Error updating Processing module - No fusion.dtm2ascii
> module installed
> Dear list, while updating complements in qgis 2.12 Lyon under Debian Stable
> amd64, an error shows up while updating "Processing" complement. It says "No
> module named DTM2ASCII". Searching I think this module is part of fusion
> software for Lidar analysis, but can't install via pip or other forms.
> Any tip?
> Thanks
> Error in complement updating:
> ImportError: No module named DTM2ASCII
> Traceback (most recent call last):
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 281, in
> loadPlugin
> __import__(packageName)
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 572, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/home/marmo/.qgis2/python/plugins/processing/__init__.py", line 29,
> in
> from processing.tools.general import *
> _import
> File "/home/marmo/.qgis2/python/plugins/processing/tools/general.py", line
> 28, in
> from processing.core.Processing import Processing
> _import
> File "/home/marmo/.qgis2/python/plugins/processing/core/Processing.py",
> line 51, in
> from processing.algs.lidar.LidarToolsAlgorithmProvider import
> _import
> File
> "/home/marmo/.qgis2/python/plugins/processing/algs/lidar/LidarToolsAlgorithmProvider.py",
> line 123, in
> from fusion.DTM2ASCII import DTM2ASCII
> _import
> Python: 2.7.9 (default, Mar 1 2015, 13:01:26) [GCC 4.9.2]
> QGIS: 2.12.0-Lyon Lyon, exported
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
