[Qgis-user] QGIS Segmentation fault
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Nov 18 22:05:36 PST 2015
He, he, thanks for the hint...
Running QGIS through gdb ("gdb ./output/bin/qgis") and then calling "bt" gave "No stack".
However, when I ran just "./output/bin/qgis" I got:
src/app/main.cpp: 428: (main) [0ms] Starting qgis main
No protocol specified
Warning: qgis: cannot connect to X server :4
Stacktrace (piped through c++filt):
./output/bin/qgis[0x40573d]
./output/bin/qgis[0x405923]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qt_message_output(QtMsgType, char const*)+0x21)[0x7f5a2f8eabb1]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x70ff9)[0x7f5a2f8eaff9]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qWarning(char const*, ...)+0x94)[0x7f5a2f8eb244]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x23db42)[0x7f5a2ee04b42]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplicationPrivate::construct(_XDisplay*, unsigned long, unsigned long)+0xc8)[0x7f5a2ed94a78]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplication::QApplication(int&, char**, bool, int)+0x69)[0x7f5a2ed94e19]
/data/src/QGIS/qgis-2.12/output/lib/libqgis_core.so.2.12.0(QgsApplication::QgsApplication(int&, char**, bool, QString const&)+0x3c)[0x7f5a3094ab70]
./output/bin/qgis[0x4072ea]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f5a2e309ec5]
./output/bin/qgis[0x405179]
src/core/qgsmessagelog.cpp: 45: (logMessage) [60ms] 2015-11-19T06:56:36 Qt[1] qgis: cannot connect to X server :4
I am running QGIS through VNC (which X Server :4 refers to). Yet, maybe the issue is due to missing restart after kernel update?
Cheers,
Sefan
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 19. november 2015 00:52
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS Segmentation fault
On Wed, 18. Nov 2015 at 23:26:25 +0000, Blumentrath, Stefan wrote:
> Thanks for the instruction. Here is my backtrace:
> pdb ./output/bin/qgis
gdb not pdb.
> From: Matthias Kuhn [mailto:matthias at opengis.ch]
> cd build
> run
> ... wait for the crash
> bt
> ... copy paste
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
