[Qgis-user] QGIS Segmentation fault
Matthias Kuhn matthias at opengis.ch
Thu Nov 19 00:21:49 PST 2015
In cmake gui is the right choice, the env variable is ignored.
Maybe you have to "make clean" before running "make" again? It seems
that there are no debug symbols available yet.
And once they are available, it seems that there's still an issue with X
of which I am not sure if it brings the application to its knees even
before it arrives at the point where the crash we are interested in is.
Cheers
Matthias
On 11/19/2015 09:05 AM, Blumentrath, Stefan wrote:
> Yes I did. Now I also tried
> export CMAKE_BUILD_TYPE=Debug
> Befor running (earlier I specified Debug in the cmake gui):
> ccmake ..
> make
> gdb ./output/bin/qgis
> Cheers
> Stefan
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
> Sent: 19. november 2015 08:05
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS Segmentation fault
> Did you make after cmake with buld type Debug and before running? Sorry, I forgot to write that...
> On 11/19/2015 07:05 AM, Blumentrath, Stefan wrote:
>> He, he, thanks for the hint...
>> Running QGIS through gdb ("gdb ./output/bin/qgis") and then calling "bt" gave "No stack".
>> However, when I ran  just "./output/bin/qgis" I got:
>> src/app/main.cpp: 428: (main) [0ms] Starting qgis main No protocol
>> specified
>> Warning: qgis: cannot connect to X server :4 Stacktrace (piped through
>> c++filt):
>> ./output/bin/qgis[0x40573d]
>> ./output/bin/qgis[0x405923]
>> /usr/lib/x86_64-linux-gnu/libQtCore.so.4(qt_message_output(QtMsgType,
>> char const*)+0x21)[0x7f5a2f8eabb1]
>> /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x70ff9)[0x7f5a2f8eaff9]
>> /usr/lib/x86_64-linux-gnu/libQtCore.so.4(qWarning(char const*,
>> ...)+0x94)[0x7f5a2f8eb244]
>> /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x23db42)[0x7f5a2ee04b42]
>> /usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplicationPrivate::construct
>> (_XDisplay*, unsigned long, unsigned long)+0xc8)[0x7f5a2ed94a78]
>> /usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplication::QApplication(int
>> &, char**, bool, int)+0x69)[0x7f5a2ed94e19]
>> /data/src/QGIS/qgis-2.12/output/lib/libqgis_core.so.2.12.0(QgsApplicat
>> ion::QgsApplication(int&, char**, bool, QString
>> const&)+0x3c)[0x7f5a3094ab70] ./output/bin/qgis[0x4072ea]
>> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f5a2e309ec5
>> ./output/bin/qgis[0x405179]
>> src/core/qgsmessagelog.cpp: 45: (logMessage) [60ms]
>> 2015-11-19T06:56:36 Qt[1] qgis: cannot connect to X server :4
>> I am running QGIS through VNC (which X Server :4 refers to). Yet, maybe the issue is due to missing restart after kernel update?
>> Cheers,
>> Sefan
>> Of Jürgen E. Fischer
>> Sent: 19. november 2015 00:52
>> On Wed, 18. Nov 2015 at 23:26:25 +0000, Blumentrath, Stefan wrote:
>>> Thanks for the instruction. Here is my backtrace:
>>> pdb ./output/bin/qgis
>> gdb not pdb.
>>> From: Matthias Kuhn [mailto:matthias at opengis.ch]
>>> cd build
>>> run
>>> ... wait for the crash
>>> bt
>>> ... copy paste
>> Jürgen
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
