[Qgis-user] Interpolation with breaklines
nicolas.cadieux at archeotec.ca nicolas.cadieux at archeotec.ca
Fri Nov 20 07:45:41 PST 2015
Have you tried the interpolation plugin in QGis?
(raster/interpolation/interpolation) if the plugin is activated.  I see
the option is available for points, structure lines and  break lines....
It seems to work if you have  a z field.  If you are using a tach or a
total station, you will probably not have too many points for this plugin.
Nicolas
Le 2015-11-20 09:40, Neumann, Andreas a écrit :
> Hi,
> No - the points are manually surveyed - field work - very precise
> surveys with Tachymeter. It is in developed areas where walls outside
> of buildings are quite frequent.
> We also have LIDAR data (quite dense from last year) - but they are
> not precise enough for certain projects that require accuracies at
> plus/minus 5cm and contour line intervals at 20-30 cm.
> I will try converting the break lines into dense points - to reach a
> similar effect than normal break lines.
> Andreas
> On 2015-11-20 14:57, Nicolas Cadieux wrote:
>> Hi again,
>> Are the irregular points LIDAR? If it is comparable in point density,
>> you could do two interpolations. One for the ground that could use a
>> larger interpolation search window and then one for the objects that
>> are above the ground with a very small search window (like 1m). After
>> that,  you could make a normalized DEM and then you can add the walls
>> to the ground model..   That would give you sharp walls feature on a
>> smooth ground DEM.
>> The PDAL library or Cloud Compare could separate buildings from the
>> ground.
>> Good luck!
>> Nicolas Cadieux M.Sc.
>> Les Entreprises Archéotec inc.
>> 8548, rue Saint-Denis Montréal H2P 2H2
>> Téléphone: 514.381.5112  Fax: 514.381.4995
>> www.archeotec.ca
>> On Nov 20, 2015 5:47 AM, "Neumann, Andreas [via OSGeo.org] " <[hidden
>> email]> wrote:
>>     Hi,
>>     At my workplace we have to generate terrain models (contour
>>     lines) from irregularly input points with heights. We also have
>>     break lines (e.g. walls) that we would like to take into account
>>     during interpolation.
>>     While there are quite a few interpolation available in GRASS or
>>     SAGA, I can't find any interpolation methods that also take break
>>     lines.
>>     I found http://grasswiki.osgeo.org/wiki/TIN_with_breaklines -
>>     which seems to do what I want, but is a separate module and
>>     builds on a "triangle" executable and is not distributed with GRASS.
>>     I have therefore two questions:
>>     1. Is this the only FOSSGIS option we have, if breaklines should
>>     be considerered during interpolation? Or are there alternatives?
>>     2. Did someone use v.traingle. this in a production environment?
>>     Does it work properly? I am just asking before I try to install it.
>>     3. If this works fine - can we try to distribute it with OSGeo4W?
>>     Thanks,
>>     Andreas
>>     _______________________________________________
>>     Qgis-user mailing list
>>     <a
>>     href="/user/SendEmail.jtp?type=node&node=5237598&i=0">[hidden
>>     email]
>>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     If you reply to this email, your message will be added to the
>>     discussion below:
>>     http://osgeo-org.1560.x6.nabble.com/Interpolation-with-breaklines-tp5237598.html
>>     To start a new topic under Quantum GIS - User, email
>>     ml-node+s1560n4125267h38 at n6.nabble.com
>>     To unsubscribe from Quantum GIS - User, <a
>>     href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
>>     here.
>>     <a
>>     href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"
>>     style="font:9px serif">NAML
>> View this message in context: Re: Interpolation with breaklines
>> <http://osgeo-org.1560.x6.nabble.com/Interpolation-with-breaklines-tp5237598p5237638.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>> at Nabble.com.
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151120/8a3051e5/attachment.html>
