[Qgis-user] The XML of getcapabilities should not have any ascii code over 128
Andrea Peri aperi2007 at gmail.com
Sun Oct 4 10:13:02 PDT 2015
In the xml response.
When it happened I go into the metadata abstracts using the qgis gui,
remove any character over 7bit code and after this the response became well
formed.
Actually we use qgis-server 2.6.
A.
Il 04/ott/2015 18:31, "Matthias Kuhn" <matthias at opengis.ch> ha scritto:
> Hi Andrea,
> On 10/04/2015 05:55 PM, aperi2007 wrote:
> Hi Mattias,
> Sorry but this question is hard to understand for me .
> Perhaps I miss to analyze another step:
> If the operating system of the user is with a character set different from
> UTF8.
> And the user is editing a qgis project.
> The qgis project what character set is using ?
> AFAIK the qgis carset is set in the properties page of qgis.
> Where exactly do you start experiencing strange behavior?
> In the text box in the properties, in the project file or only in the XML
> response from the server?
> -- Matthias
> If this is true,
> How can the clipboard of the operating system to know what is the charset
> set in the properties page of qgis ?
> AFAIK the clipboard change always and only in the charset of the OS.
> A.
> Il 04/10/2015 15:30, Matthias Kuhn ha scritto:
> Hi Andrea,
> Is it really that there should only be 7bit characters or is it that the
> encoding is not properly set in the answer?
> XML fully supports utf-8 (it is even the default character encoding) and
> I assume that in 2015 every modern XML client should support this as well.
> Can you give an example server address and ideas of affected clients?
> I have the feeling that there's something else fishy and if there is
> really a need to replace characters above 127 then it should be an
> opt-in configuration option.
> Matthias
> On 10/04/2015 11:59 AM, Andrea Peri wrote:
> Hi,
> we experienced this user case problem.
> In the qgis-server getcapabilities response the information of the
> "Abstract" is taken from the field:
> layer-properties -> metadata -> Abstract.
> But ofet the user fill this field with some cut/paste from other documents.
> So doing, if fill this field with many unacceptable character.
> Like these:
> or the very hard to see "no blank space".
> The qgis accept all of this without any problem,
> but when return the repsonse from a GetCapabiities request.
> The response is not valid for the xml.
> So many standard xml clients report a not well formed xml.
> We don't have any good ideas to how resolve this issue.
> My question is if could be possible in the qgis-server site to do a
> xml conversion of all this character.
> Instead of send them directly.
> AFAIK all of this could be coded to be corected coded in a XML response.
> Any thought on this ?
> Thx.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151004/81b0660e/attachment.html>
