[Qgis-user] Editable GeoCSV
Peter Borbely pborbely at fairfaxmedia.com.au
Mon Oct 5 16:17:35 PDT 2015
Thanks Nath, this worked
Peter Borbély
<myemail at fairfaxmedia.com.au>
Interactivista
Fairfax Media
1 Darling Island Road, Pyrmont 2009
+61 2 8596 4745
pborbely at fairfaxmedia.com.au | @datafunk <http://twitter.com/datafunk>
On 5 October 2015 at 13:59, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> On Mon, Oct 5, 2015 at 12:20 PM, Peter Borbely <
> pborbely at fairfaxmedia.com.au> wrote:
>> QSettings().setValue('locale/userLocale', 'en_AU')
> For some reason that setting is null when the plugin asks for it but not
> in the options which I'm not sure why. This is a external plugin so the
> author will need that handle that case.
> Here are some workarounds for now.
> Run this:
> from PyQt4.QtCore import *
> You need to import the module and then use the settings class.
> Or you can put the attached file into .qgis2\python\plugins\editablegeocsv
> folder.  I have patched this file so it should work.
> Regards,
The information contained in this e-mail message and any accompanying files
is or may be confidential. If you are not the intended recipient, any use,
dissemination, reliance, forwarding, printing or copying of this e-mail or
any attached files is unauthorised. This e-mail is subject to copyright. No
part of it should be reproduced, adapted or communicated without the
written consent of the copyright owner. If you have received this e-mail in
error please advise the sender immediately by return e-mail or telephone
and delete all copies. Fairfax Media does not guarantee the accuracy or
completeness of any information contained in this e-mail or attached files.
Internet communications are not secure, therefore Fairfax Media does not
accept legal responsibility for the contents of this message or attached
files.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151006/e7cde966/attachment.html>
