[Qgis-user] Aggregate tool not working
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sat Oct 10 03:01:05 PDT 2015
Am 10.10.2015, 11:06 Uhr, schrieb Micah Duckworth
<micah.duckworth at askham-bryan.ac.uk>:
> I am a new Qgis user using the latest version. I am wanting to do a
> simple cell aggregation of a >raster in order to use it in another
> application so have tried the aggregate algorithm.
> First question: the parameter entry window does not show an option to
> specify the output file, as >there is for other algorithms. Is it
> missing, or will it just output to a temporary file?
> Secondly, the algorithm fails to run anyway! The log shows the following
> errors which seem to show >failure to load dlls. What should I try?
> Algorithm Aggregate starting...
> grid_tools "Aggregate" -INPUT
> "C:\Users\m\AppData\Local\Temp\processing>\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd"
> -SIZE 3 -METHOD 0
> C:\PROGRA~1\QGISPI~1\bin>set SAGA=C:/PROGRA~1/QGISPI~1/apps\saga
> SAGA_MLB=C:/PROGRA~1/QGISPI~1/apps\saga\modules
> C:\PROGRA~1\QGISPI~1\bin>PATH=PATH;C:/PROGRA~1/QGISPI~1/apps\saga;C:/PROGRA~1/QGISPI~1/apps>\saga\modules
> C:\PROGRA~1\QGISPI~1\bin>saga_cmd grid_tools "Aggregate" -INPUT
> "C:\Users\m\AppData\Local>\Temp\processing\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd"
> -SIZE 3 -METHOD 0
> ERROR 1: Can't load requested DLL:
> C:\PROGRA~1\QGISPI~1\apps\saga\dll\gdal_MrSID.dll
> 127: The specified procedure could not be found.
Looks like this algo is somehow incomplete/has a bug.
I got it working with a test tif though:
In your log, you see the path to a result sgrd file. I tried to load this
manually, but QGIS does not recognise it.
Then I searched about "gdal" and "sgrd" and learned, that there is a sdat
file with the same name in the directory.
This can be loaded manually.
What I cannot reproduce is your error with gdal_MrSID.dll
Is your input a .sid file?
Then try converting to a tif, run the algo and manually load the sdat file
 from the path mentioned in the log.
Good luck
Bernd
> _____________________________________________
> library path: C:\PROGRA~1\QGISPI~1\apps\saga\modules\grid_tools.dll
> library name: Grid - Tools
> tool name : Aggregate
> author : Victor Olaya (c) 2005
> Load grid:
> C:\Users\m\AppData\Local\Temp\processing>\e163dc05746341b68f5aff8371cebcb6\woodrasbinary.sgrd...
> Parameters
> Grid system: 10; 6138x 6682y; 360035.92025x 447990.557700y
> Grid: woodrasbinary
> Aggregation Size: 3
> Method: sum
> C:\PROGRA~1\QGISPI~1\bin>exit
> Converting outputs
> Loading resulting layers
> Algorithm Aggregate finished
>> The information in this email is confidential and is intended solely
>> for the addressee, access to this email by anyone else is unauthorized.
>> If you are not the intended recipient, you must not read, use >or
>> disseminate the information. Any views expressed in this message are
>> those of the individual sender, please note that any views or opinions
>> presented in this email may be personal to the author >and do not
>> necessarily represent the views or opinions of Askham Bryan College. It
>> is the responsibility of the recipient to check this email for the
>> presence of viruses; Askham Bryan College accepts >no liability for any
>> damage caused by any virus transmitted by this email.
> http://www.askham-bryan.ac.uk/
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151010/3f7a1d42/attachment.html>
