[Qgis-user] QGIS plugin with python
Emilio S emiliosjlc at hotmail.com
Fri Oct 23 09:54:00 PDT 2015
Thank you and sorry.I have tried to connect to spatialite with this code, but this doesn´t add anything. Could you know why?
from PyQt4.QtCore import *from PyQt4.QtGui import *uri=QgsDataSourceURI()uri.setDatabase('C:\Users\pr\Desktop\GIS.sqlite')schema=' 'table ='ambi'geom_column= 'geom'uri.setDataSource(schema, table, geom_column)display_name=('prueba')vlayer=QgsVectorLayer(uri.uri(), display_name, 'spatialite')
Thanks
Subject: Re: QGIS plugin with python
To: emiliosjlc at hotmail.com; qgis-user at lists.osgeo.org
Date: Fri, 23 Oct 2015 09:29:13 -0400
    Emilio,
    Please reply to the QGIS users list so others will benefit from the
    discussion.  :)
    Your next reading would probably be the QT4 and PyQt4 documentation
    for the SQL database classes.
    QT4 is the c++ version of the code.
    PyQt4 is the python wrappers around QT4.
    While you will be coding in python, the c++ documentation may be
    helpful and clearer to read.
    Google has been my friend.  :)
    Here are a few links to get you started.
    http://doc.qt.io/qt-4.8/sql-connecting.html
    http://pyqt.sourceforge.net/Docs/PyQt4/index.html
    http://pyqt.sourceforge.net/Docs/PyQt4/qsqldatabase.html
http://stackoverflow.com/questions/7669987/what-is-the-correct-way-of-qsqldatabase-qsqlquery
    I'm sorry don't have an example available at the moment. I cannot
    promise I'll find the time to put one together.
    Worth Lutz
    On 10/23/2015 8:47 AM, Emilio S wrote:
      Thank you Worth Luz for your explanation. I have
        started with this and I have read a lot, but do you know any
        example to conect python with spatialite and do a SQL query?
        Thank you again
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151023/da57b943/attachment.html>
