[Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
Piotr Kania p.kania at op.pl
Fri Oct 30 03:39:13 PDT 2015
Hi all,
as a workaround try to use DNRGPS - it's free app
(http://www.dnr.state.mn.us/mis/gis/DNRGPS/DNRGPS.html). In settings
it's possible to set up your country epsg code, in that way all
waypoints and traces transfered from garmin receiver to DNRGPS can be
saved as shp in your preferred crs. If you would like to have altitude
as a attribute in created shp you have to play around with waypoint
settings - altitude column should be sth else than in default setting
(string or number)
W dniu 2015-10-30 o 11:09, Markus Weidenbach pisze:
> Hi Antonio,
> I have the same problem with the same GPS device (Garmin GPSMap 76CSx)
> connected via USB cable to my Win 7 and QGIS 2.8: QGIS does not
> recognize the Garmin device.
> The USB driver is updated from the Garmin webpage and the connection
> works to transfer data to the SD Card of Garmin using the windows
> explorer ....
> Did you meanwhile find any solution?
> Regards,
> Markus
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77815 Bühl
> Germany
> e.mail see: http://landConsult.de
> Am 10.07.2015 um 15:45 schrieb Antonio Di Marco:
>> Hi Lene thanks for your reply, the problem is not to open the GPX but
>> is to download data with  GPS Tools plug-in to directly show
>> waypoints an the map.
>> It seems that GPS Tools doesn't recognize my garmin76Csx and so the
>> download fails.
>> Il 10/07/2015 14.35, Lene Fischer ha scritto:
>>> Hi Antonio,
>>> You can open a GPX- file as any other vector file. Just remember to
>>> choose the extension .GPX
>>> The plugin is not needed to open.
>>> Regards
>>> *Lene Fischer*
>>> Associate Professor
>>> *Department of Geosciences and Natural Resource Management*
>>> University of Copenhagen
>>> MOB +45 40115084
>>> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
>>> cid:image001.gif at 01D03029.2F3EC6A0
>>> *Fra:*qgis-user-bounces at lists.osgeo.org
>>> [mailto:qgis-user-bounces at lists.osgeo.org] *På vegne af *Antonio Di
>>> Marco
>>> *Sendt:* 9. juli 2015 16:35
>>> *Til:* qgis-user at lists.osgeo.org
>>> *Emne:* [Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
>>> In QGIS 2.8.2 I couldn't download my Garmin GPS waypoints through
>>> Vector -- GPS Tools menu under an USB connection.
>>> The device has this Command line under "Waypoint download":
>>> %babel -w -i garmin -o gpx "%in" "%out"
>>> I tried also this line: gpsbabel -w -i garmin -o gpx "%in" "%out"
>>> In both cases I get this message:
>>> *Layer is not valid: *The layer xxxx.gpx?type=waypoint is not a
>>> valid layer and can not be added to the map
>>> I need an usb connection not a serial one via COM1
>>> To verify that was not a driver trouble or something else I tried to
>>> gat the waypoints via GPSBABEL and everything is ok
>>> Any answer will be very much appreciated
>>> Antonio Di Marco
>>> ARPAT (Agenzia Regionale per la Protezione Ambientale della Toscana)
>>> Direzione tecnica - Settore SIRA (Sistema Informativo Regionale Ambientale)
>>> Via N. Porpora, 22
>>> 50144 Firenze
>>> Tel.: +39-055-3206416  Fax: +39-055-3206324
>>> email:antonio.dimarco at arpat.toscana.it
>>> <mailto:antonio.dimarco at arpat.toscana.it>
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/eb862066/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/eb862066/attachment.gif>
