[Qgis-user] QGIS 2.12 packaging for Ubuntu 14.04?
Jürgen E. Fischer jef at norbit.de
Sat Oct 31 11:39:48 PDT 2015
Hi Giovanni,
On Fri, 30. Oct 2015 at 16:27:46 +0100, G. Allegri wrote:
> > /usr/bin/ld: CMakeFiles/globeplugin.dir/globe_plugin.cpp.o: relocation R_X86_64_PC32 against undefined symbol `_ZNK8osgEarth13ConfigOptions9getConfigEv' can not be used when making a shared object; recompile with -fPIC
> > /usr/bin/ld: final link failed: Bad value
> > collect2: error: ld returned 1 exit status
> > The i386 build was ok, but also not include because of the amd64 failure.
Looks like it's a problem ubuntugis' osgearth when the globe plugin is built
with limited symbol visibility ie. -fvisibility=hidden
-fvisibility-inlines-hidden.
Doesn't happen without, doesn't happen with the nightlies (built with debugging
symbols), does only affect amd64 and doesn't happen with ubuntu's regular
osgearth either.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151031/31c4f087/attachment.sig>
