[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Sandro Santilli
strk at keybit.net
Tue Sep 1 04:48:33 PDT 2015
I agree with Luca this should have been better not backported to 2.8.3.
Only proper bugs should be backported, and this was a (debatable)
GUI enhancement, as far as I can tell.
BTW: resolution of #11317 is set to "wontfix"
--strk;
On Mon, Aug 31, 2015 at 09:00:15PM +0200, Luca Lanteri wrote:
> Hi,
> I noticed that this new behavior has been backported to 2.8.3.
> I think this behavior should be considered a regression because now it's
> very uncomfortable to load views, specially when I have to load many views.
> I also noticed that lot of users are confused, because they thinks that
> views doesn't work. I think the old behavior was better because it allowed
> both to choose a custom gid and to load view faster.
> Currently we decide to remain with 2.8.2.
> What about reconsidering to return to the old behavior ?
> Thanks
> Luca
> 2015-08-06 20:58 GMT+02:00 Jürgen E. <jef at norbit.de>:
> > Hi Randal,
> > On Thu, 06. Aug 2015 at 13:53:08 -0400, Randal Hale wrote:
> > > In 2.8.x I can add the view and the Primary key is automatically
> > displayed.
> > No, you're supposed to select the primary key. In 2.8.x you also have to
> > choose from all columns, but first one is preselected. If that happens to
> > be
> > the primary key, you're fine, but that's not always the case and hence
> > newer versions force you to actually select it.
> > Jürgen
> > Jürgen E. Fischer norBIT GmbH Tel.
> > +49-4931-918175-31
> > Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> > +49-4931-918175-50
> > Software Engineer D-26506 Norden
> > http://www.norbit.de
> > QGIS release manager (PSC) Germany IRC: jef on FreeNode
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
