[Qgis-user] DXF Export in QGIS 2.10
Andreas Neumann a.neumann at carto.net
Tue Sep 1 06:06:13 PDT 2015
Hi Thomas,
libreCAD is extremely limited with its DXF Import  and capabilities in
general. Apparently it can't correctly deal with labels. QCAD or
Draftsight do a slightly better job than libreCAD. The export was
optimized for compatibility with Autocad and FME. This is our reference.
They both read the files fine.
You should ask at the libreCAD project, if they can't correctly read the
DXF file.
If we wouldn't export the Font/Text properties, the Autocad users would
complain that the text does not match how it looked like in QGIS ...
Andreas
On 01.09.2015 14:59, Thomas Cürten (WhereGroup) wrote:
> Hello everyboy,
> I have a question towards the DXF Export in QGIS 2.10 . When I try to
> export a project from QGIS into a DFX-file and open it in libreCAD,
> the labels are not presented correctly. Some of them don't appear at
> all, others are slightly dislocated and display further information
> towards character type, hight and so on in front of the actual label
> (e.g. Ubuntu|i0|b1;\H54.5776;/W0.75; Church).
> Do you have any suggestions how i can avoid the additional
> label-information, export all labels into the dfx-file and get them in
> the right position?
> Thanks
> Thomas
> Qgis-user mailing list
