[Qgis-user] Black/White and colors maps
Shane
shaned173 at gmail.com
Thu Sep 3 18:56:01 PDT 2015
I have the need to create two maps; one with color and the other
black and white. The color map has trails (in several shapefiles) with
each trail a different color. The other map has the same trails (same
shapefiles) but each trail is represented as a dashed black line.
The brute force way to do this is to add two layers of the same
shapefile (with different layer names of course). Then in the
Properties of each layer, modify the line style as needed. I've done this.
What about using the "Data defined properties ..." button in the
simple line style properties dialog? Is that possible? But I don't
understand how I would trigger the selection of the required style.
(I'm using QGIS 2.6. Yes I know, a dinosaur, but it's working.)
Shane
