[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Sep 3 23:49:08 PDT 2015
Hi Andrea,
by reading out pg_constraint [1]
if a UNIQUE constraint is defined the uniqueness is guaranteed by the
db, no need for QGIS to also check it.
Bernhard
[1]
http://www.postgresql.org/docs/9.4/interactive/catalog-pg-constraint.html
Am 04.09.2015 um 08:42 schrieb Andrea Peri:
> Ho,
> How do qgis to analyze the table to retrieve the unique?
> A loop on every record or a SQL to count distinct ?
> A.
> Il 04/set/2015 08:01, "Bernhard Ströbl" <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>> ha scritto:
> Am 03.09.2015 um 23:41 schrieb Sandro Santilli:
> On Wed, Sep 02, 2015 at 08:48:34AM +0200, Bernhard Ströbl wrote:
> Am 01.09.2015 um 17:49 schrieb Matthias Kuhn:
> 2. If there are tables without a PK open a second modal
> dialog with an
> explanation of the problem and offer to select a pk from
> a combobox.
> I hope you mean "relation" not table, a table should always
> have a
> PK.
> It's not mandatory for a table to have a PK.
> I guess by "tables without a PK" he means table for which no PRIMARY
> KEY constraint is explicitly defined (should an UNIQUE key be
> considered equally valid?).
> It is not mandatory, of course, that's why I wrote "should", but
> IMHO it is very bad database design to not define one.
> There might be several UNIQUE constraints on one table but there can
> be only one PK constraint. So in case of only a UINIQUE constraint
> the table would be handled as any other without PK constraint (or
> QGIS needs to analyse how many fields have a UNIQUE constraint).
> Bernhard
> __________ Information from ESET Mail Security, version of virus
> signature database 12200 (20150904) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
__________ Information from ESET Mail Security, version of virus signature database 12200 (20150904) __________
http://www.eset.com
