[Qgis-user] Making oblique maps in Qgis: is it possible?
Enrique filonio at gmail.com
Fri Sep 11 04:46:23 PDT 2015
You can try to build a 3d view with Qgis2threejs plugin. It's very nice!
- If you don't have a base DEM, you can select "Flat plane" option, to
start testing
- you are able to export labels to display in the 3D space
- test some interesting output options...
The html file can be opened with a browser with Webgl capabilities (not
very aged PCs).
Enrique.
2015-09-11 11:00 GMT+02:00 Jens Verwaerde | Natuurpunt CVN <
jens.verwaerde at cvn.natuurpunt.be>:
> I'd like to make an oblique (bird's eye) view of some of my maps.
> Theoretically this is possible by exporting a map to an image manipulation
> program and then using a tilting function, but ... that's an extra step and
> ... everything on the map is then "obliqued" including labels etc.
> But I don't want everything to become oblique; text labels, arrows etc.
> should stay "normal" and floating in the air above the map, so only the map
> should be oblique.
> Also is it possible to have diagrams that "point from the sky" to the
> location on the oblique map instead of also becoming oblique?
> Jens Verwaerde
> lesgever natuurbeheer en natuurfotografie
> t: 015 29 72 29 | gsm: 0491 15 03 57
> Website: http://cvn.natuurpunt.be
> Facebook: www.facebook.com/NatuurpuntCVN
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150911/b889d16f/attachment.html>
