[Qgis-user] image export ?
Sashikumar N
sashikumar.n at gmail.com
Mon Sep 14 23:46:59 PDT 2015
You should try "Print Composer" to export all layers as an image, it has
option for setting resolution. Have to check if it has options for
compression.
regards
sashi
On Fri, Sep 11, 2015 at 4:50 PM, image93 <lcelati at cci-paris-idf.fr> wrote:
> Good afternoon,
> In input, i have a raster *tif file (resolution : 50 cms / compress mode
> JPEG with compress quality 75/100).
> I would like to do an georeferenced export representing the raster file and
> several vector files that i added the in map canvas
> Idealy,in output, i would like create a file with the same input parameters
> (tif format, 50 cms resolution, compress mode jpef 75/100) .
> Is it possible to do that with qgis?
> Thanks.
> http://osgeo-org.1560.x6.nabble.com/image-export-tp5223779.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Thankyou
regards
sashi
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150915/75265bfa/attachment.html>
