[Qgis-user] Saving qgs project file takes forever on VPN - no problem with data
John Harrop jcharrop at gmail.com
Tue Sep 15 10:15:49 PDT 2015
Is the VPN doing the locking or QGIS?  We used QGIS with shapefile data over Dropbox and had a few conflicts with accidental multiple editors.  We now enforce read only to everyone except the directory owner (using Dropbox to enforce).  That has worked fine.
I have fairly slow saves, but I must admit its getting to be a big project.  Smaller ones (also on Dropbox) are fine.  But Dropbox should appear to QGIS as local files with the synchronization going on in the background.
Regards,
John
> On Sep 15, 2015, at 3:02 AM, Matt Boyd <mattslists at gmail.com> wrote:
> I'm pretty sure there's a lockfile that stops you from doing that. Also, I've found most layers (shapefiles in particular) are locked so they can't be edited by other applications while qgis has them.
> Matt
> On 15 Sep 2015 19:58, "Michael.Dodd" <michael.dodd at open.ac.uk <mailto:michael.dodd at open.ac.uk>> wrote:
> And what happens if more than one person at once tries to edit the project on the server. There are 3 people all working on one project, we plan to do it in turns, what happens if we make a mistake and try to open the main project or edit some of the layers on the server two people at the same time via vpn (we are physically in different parts of the country).
> ________________________________________
> From: qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> [qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org>] on behalf of magerlin [MAP at ramboll.dk <mailto:MAP at ramboll.dk>]
> Sent: Tuesday, September 15, 2015 10:23 AM
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Saving qgs project file takes forever on VPN - no problem with data
> Just a minute ago I edited my post by adding that AutoSaver is just as slow
> Regards Morten
> Currently using Qgis 2.10.1 (OSGeo4),
> Windows 7, 64bit
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Saving-qgs-project-file-takes-forever-on-VPN-no-problem-with-data-tp5224216p5224245.html <http://osgeo-org.1560.x6.nabble.com/Saving-qgs-project-file-takes-forever-on-VPN-no-problem-with-data-tp5224216p5224245.html>
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> -- The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302). The Open University is authorised and regulated by the Financial Conduct Authority.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150915/69860554/attachment.html>
