[Qgis-user] SVG borders with data defined override in Postgis layer
didier peeters dpeeter1 at ulb.ac.be
Thu Sep 17 13:37:53 PDT 2015
Hello,
I have a problem with the border parameter of SVG markers in QGis 2.10 (on Mac OS 10.10.5); I’m using PostGIS layers and the SVG markers properties are determined by the DB, i.e. the svg itself, the color, the rotation, with data define override.  I also want to define the border color and width the same way but it doesn’t work, nothing happens.  If I deactivate the overriding everything is correct.
For the color I use a varchar type (same as for the color of the svg itself) and for the width a numeric (also tried real, double precision, …) .
I haven’t found any bug report about this.  Any idea ?
Didier
