[Qgis-user] SVG borders with data defined override in Postgis layer
Andreas Neumann a.neumann at carto.net
Fri Sep 18 06:32:32 PDT 2015
Hi Didier,
I had a quick check with QGIS 2.10 and QGIS master. While overriding of
stroke-color works fine, the overriding of the stroke-width
(param(outline-width)) is broken in both versions. As far as I can tell
your SVG symbol seems to be properly prepared.
Can you please open a bug report for this and attach a simple demo
project and your SVG file?
Thanks,
Andreas
On 18.09.2015 14:57, didier peeters wrote:
> Hi Andreas,
> yes, I can define a border width ‘manually’ in the styling of the
> layer, but I cannot override this with a value from Postgis.
> I will send you a svg.
> Didier
> See also
> http://blog.sourcepole.ch/2011/06/30/svg-symbols-in-qgis-with-modifiable-colors/
>> Le 18 sept. 2015 à 14:42, Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> a écrit :
>> Hi Didier,
>> Did you prepare your SVG file accordingly?
>> You need something like the following in your SVG file wherever you
>> want to dynamically replace properties:
>> <rect fill="param(fill) #ff0000" stroke="param(outline) #00ff00"
>> stroke-width="param(stroke-width) 10" width="100" height="100">
>> Can you share your SVG file so I can have a look if it is properly
>> prepared?
>> Andreas
>> On 18.09.2015 14:36, didier peeters wrote:
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> I can refine my description :
>>> the problem occurs on the border width only, the border color works
>>> fine.
>>>> Still, no one has ever met this problem ?
>>>> Didier
>>>> Le 17 sept. 2015 à 22:37, didier peeters <dpeeter1 at ulb.ac.be> a écrit :
>>>> I have a problem with the border parameter of SVG markers in QGis
>>>> 2.10 (on Mac OS 10.10.5); I’m using PostGIS layers and the SVG
>>>> markers properties are determined by the DB, i.e. the svg itself,
>>>> the color, the rotation, with data define override. I also want to
>>>> define the border color and width the same way but it doesn’t work,
>>>> nothing happens. If I deactivate the overriding everything is correct.
>>>> Hello,
>>>> I haven’t found any bug report about this. Any idea ?
>>>>> For the color I use a varchar type (same as for the color of the svg itself) and for the width a numeric (also tried real, double precision, …) .
>>>>> Didier
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/bbb666df/attachment.html>
