[Qgis-user] Concatenate address fields with NULLS
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Sep 20 03:43:49 PDT 2015
Am 20.09.2015, 09:54 Uhr, schrieb Phil (The Geek) Wyatt
<phil at wyatt-family.com>:
> Hi Folks,
> I am working with LIST Address Points data from
> http://listdata.thelist.tas.gov.au/opendata/ >(Specifically Clarence
> Municipality) and I need to concatenate into one field the full address
> of >each location. I am struggling to figure out how to do it when there
> are fields for unit numbers, >building names, numbers to and from etc.
> Many of the fields are also NULL so clearly I want those >fields
> disregarded.
> Can someone give me a quick heads up on how to NOT add the data from a
> field that has NULL?
> Chances are I will be doing this regularly so I am keen to document the
> required expressions for >others to use as well.
> Cheers - Phil
> Volunteer Mapper - Red Cross
having NULL values in attributes is not easy to handle for those who have
no idea what terms to search for on the internet.
There is the coalesce function in field calculator:
coalesce("Fieldname1",'') will return your attribute, in case its NULL it
will return en empty string (or what ever you like).
Concatenating coalesce("Fieldname1",'') || coalesce("Fieldname2",'') ...
But this will just paste together all attributes, so add || ' ' to the
field name to get spaces between the attributes.
coalesce("Fieldname1" || ' ','') || coalesce("Fieldname2" || ' ','') ...
(it seems that this handles NULL & something = NULL)
For a lot of fields, this is a boring work to put it into the expression
editor , so I normally paste the attribute table (click the up-left margin
cell to mark everything, then hit ctrl-c) into a spreadsheed. Delete all
data except the header line, clip and insert this line transposed, so it
starts in cell A1 downwards.
in cell B1 start ="coalesce(" & A1 & " ||'','') ||
and drag this down.
You can than just copy the range it paste it into the expression editor in
QGIS. Remove the last ||
Hope this helps.
Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150920/d84feabf/attachment.html>
