[Qgis-user] Digitizing poly-lines
Johan Nilsson
joni8135 at gmail.com
Sun Sep 20 04:46:22 PDT 2015
Then I digitize a raster map and click on a line objekt on the raster map.,
red markers for nodes appears from lines in the raster map..
It's happen when I use 'Node tool' then a shp-layer are editable, but I can
not save then. The red square-vertex also appears in 'Vertex table' if
Advance digitizing is active. I'm not shure how it appears or if the a plug
for that and sometimes actives.
QGIS version
2.11.0-Master
QGIS code revision
exported <https://github.com/qgis/QGIS/commit/exported>
Compiled against Qt
4.8.6
Running against Qt
4.8.6
Compiled against GDAL/OGR
1.11.2
Running against GDAL/OGR
1.11.2
Compiled against GEOS
3.4.2-CAPI-1.8.2
Running against GEOS
3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version
9.3.4
SpatiaLite Version
4.1.1
QWT Version
5.2.3
PROJ.4 Version
480
QScintilla2 Version
2.8.1
This copy of QGIS writes debugging output.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150920/c4fbb7c4/attachment.html>
Name: Screenshot from 2015-09-14 14_32_35.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150920/c4fbb7c4/attachment.jpg>
