[Qgis-user] Geoprocessing dissolve tool
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Sep 21 07:11:04 PDT 2015
You can use the Saga dissolve (via processing toolbox).  It is faster then QGIS's but I think they are working on a solution for that.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Sep 21, 2015 05:28, "Lene Fischer [via OSGeo.org]" <ml-node+s1560n5225172h93 at n6.nabble.com> wrote:
	I have reported a bug   https://hub.qgis.org/issues/13167  It´s still open...
Regards
Lene Fischer
-----Oprindelig meddelelse-----
Fra: [hidden email]  [mailto: [hidden email] ] På vegne af Julie Pierson
Sendt: 21. september 2015 10:43
Til: [hidden email]
Emne: [Qgis-user] Geoprocessing dissolve tool
Hi all,
I tried using the dissolve tool from the QGIS geoprocessing tools and all features get dissolved together, resulting in only one feature, regardless of the dissolve field. I tried with several datasets. Do you have the same problem or is it only me ? I've used this tool in the past, and it worked ok.
Thanks for your help !
Julie.
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Geoprocessing-dissolve-tool-tp5225157p5225172.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoprocessing-dissolve-tool-tp5225157p5225268.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/2915cb91/attachment.html>
