[Qgis-user] no data in raster calculator NDVI
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Apr 5 06:20:54 PDT 2016
I don't use NDVI raster calculation but if you have no data values where you thinks you have some data, then my first reaction would be to see if all the layers are in the same CRS in case the plugin does not reprojection on the fly...
 You are using more than one layer?  Maybe add information  on what exactly you are doing. That would help others help you.
Cheers!
Nicolas
Nicolas
On Apr 5, 2016 08:45, "Mariana Buzzi-2 [via OSGeo.org]	" <ml-node+s1560n5259726h67 at n6.nabble.com> wrote:
	Hi everybody!!!! I'm doing a calculation with NDVI raster calculator. When I generate the calculation results I get a lot of pixels without values (no data). How I can do to fill those values with data? Thank you so much!!!! Regards, Mariana
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726p5259730.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160405/55c16e0b/attachment.html>
