[Qgis-user] Problems importing layers to SpatiaLite database
Christophe Damour
sigeal at sigeal.com
Thu Apr 7 05:53:20 PDT 2016
Sorry for double posting, but my first message is waiting for moderation
because of attach file size...
I am trying to import a PostGis layer into a SpatiaLite database, using
QGIS Database Manager import function.
The PostGis layer has a string primary key, and I want to keep that
primary key.
To keep the primary key, I check "Primary key" option and type the name
of the PostGis primary key field, but the result is an empty column...
I tried to workaround this problem by keeping primary key values in a
second column and getting them back after the import, this used to work
with QGIS V2.8, but doesn't anymore with QGIS V2.14.
Here is the result I get :
- When opened in QGIS Database Manager, I can see correct values in the
id column.
- When opened in QGIS, every record has the same id value.
So my questions are :
- Why isn't it possible to keep PostGis primary key when importing to
SpatiaLite with QGIS Database Manager ?
- How to workaround this problem ?
Thank you for helping,
Christophe
Le 07/04/2016 à 14:01, Christophe Damour a écrit :
> Hi,
> using QGIS Database Manager import function.
> primary key.
> name of the PostGis primary key field, but the result is an empty
> column...
> work with QGIS V2.8, but doesn't anymore with QGIS V2.14.
> Attached to this message is an example SpatiaLite database that
> illustrates the result I get :
> the id column.
> Christophe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160407/64c6dcf9/attachment.html>
