[Qgis-user] no data in raster calculator NDVI
Mariana Buzzi
marianabuzzi86 at gmail.com
Thu Apr 7 10:08:40 PDT 2016
Hi!!!
I am working with SPOT 5 image. First I transforme the image with TOA
plugin, and with datas I did the NDVI.To perform the calculation of NDVI I
use the raster calculator. In QGIS v. 2.8.3. From the Raster tool -> Raster
calculator. And there select the appropriate bands for the calculation
(NIR-R / NIR + R). The output file generated is a geotiff, which has a
large number of pixels no data (no data). Therefore I would like to know
why this occurs and how I can do about it.
Thanks!!!
Regards,
Mariana
2016-04-05 12:10 GMT-03:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi Marina,
> Please post more information on the exact calculation you are using. This
> could help:
> http://gis.stackexchange.com/questions/103122/how-to-generate-a-ndvi-in-qgis
> Nicolas
> Le 2016-04-05 10:34, Mariana Buzzi-2 [via OSGeo.org] a écrit :
> Thanks Nicolas!
> But...I check the CSR and It is right. I didn´t work with more than one
> layer...
> Any idea please!???
> Regards,
> Mariana
> 2016-04-05 10:20 GMT-03:00 Nicolas Cadieux <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5259748&i=0>>:
>> Hi,
>> I don't use NDVI raster calculation but if you have no data values where
>> you thinks you have some data, then my first reaction would be to see if
>> all the layers are in the same CRS in case the plugin does not reprojection
>> on the fly...
>> You are using more than one layer? Maybe add information on what
>> exactly you are doing. That would help others help you.
>> Cheers!
>> Nicolas
>> Nicolas
>> On Apr 5, 2016 08:45, "Mariana Buzzi-2 [via OSGeo.org] " <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5259730&i=0>> wrote:
>> Hi everybody!!!!
>> I'm doing a calculation with NDVI raster calculator. When I generate the
>> calculation results I get a lot of pixels without values (no data). How I
>> can do to fill those values with data?
>> Thank you so much!!!!
>> Regards,
>> Mariana
>> Qgis-user mailing list
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5259726&i=0">[hidden
>> email]
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5259748&i=1>
>> To unsubscribe from Quantum GIS - User, <a href="<a
>> class="moz-txt-link-freetext"
>> href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node&%2361;4125267&code&%2361;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&%2361;&%2361>;">click
>> here.
>> <a href="
>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
>> style="font:9px serif">NAML
>> View this message in context: Re: no data in raster calculator NDVI
>> <http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726p5259730.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5259748&i=2>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5259748&i=3>
> below:
> http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726p5259748.html
> <http:///user/SendEmail.jtp?type=node&node=5259755&i=0>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> <http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726p5259755.html>
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160407/6ec049f9/attachment.html>
