[Qgis-user] crash when loading svg marker
Joris Hintjens jorishin at gmail.com
Thu Apr 28 05:59:53 PDT 2016
Dear Richard
THANKS! Problem solved. For some strange reason, the Settings/Options/System/SVG-Path pointed to my desktop. Don’t know why. Fiexed now.
grateful,
Joris
> Op 23 apr. 2016, om 17:03 heeft Richard Duivenvoorde <rdmailings at duif.net> het volgende geschreven:
> Hi Joris,
> NOT confirmed here (but on Debian, don't own a Mac), I opened your
> project and changed all point layers to svg symbols without a problem...
> Are you sure Settings/Options/System/SVG-Path is empty? And not pointing
> to some strange dir or so?
> Did you already try to open this project on another (mac) system?
> And what about opening QGIS from the command line with
>  qgis --configpath /tmp
> so you will have no active plugins and start with a fresh configuration?
> Does that help, maybe?
> Regards,
> On 22-04-16 20:27, Joris Hintjens wrote:
>> Dear NYell,
>> Thanks for your remark,
>> It’s the standard QGIS svg file directory , changed nothing to these
>> settings, and I did not recently change any svg within that directory.
>> Joris
>>> Op 22 apr. 2016, om 14:05 heeft Nyall Dawson <nyall.dawson at gmail.com
>>> <mailto:nyall.dawson at gmail.com>> het volgende geschreven:
>>> It's likely there's a bad SVG somewhere in your svg search paths which
>>> is causing this crash.
>>> If you can track down which one it is and share it then I should be
>>> able to avoid the crash.
>>> Nyall
>>> On 22 Apr 2016 21:44, "Joris Hintjens" <jorishin at gmail.com
>>> <mailto:jorishin at gmail.com>> wrote:
>>>> Hello,
>>>> Just upgraded to 2.14 on OSX Capitan.
>>>> Fooling around a bit, made a project (accessible on
>>>> https://dl <https://dl/> dropboxusercontent com/u/23700421/test zip
>>>> (replace spaces with dots)
>>>> When I try to change the style of one of the point layers to a SVG,
>>> QGIS cra&shes.
>>>> (Layer properties>style>marker> change drop down from “stanard” to
>>> “svg” and BOOM.
>>>> worked fine on 2.12
>>>> any ideas where to look to solve this problem?
>>>> thanks
>>>> Joris
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
