[Qgis-user] MapInfo Attribures
damien stephens damien.stephens at gmail.com
Wed Aug 3 02:52:11 PDT 2016
If you have MapInfo wth discover, you can save the colour scheme for each
polygon as a new column in the tab file, then use that to colourise it via
the properties, styles menu in qgis.
Failing that if you have a screen grab of the map/tab file you can
categorise the features   in qgis  by one of the other attributes then use
the colour dropper tool to select each of the colours. It can be very
laborious for a large and multicoloured map, but does get a very similar
output.
Other than those options, I haven't seen a MapInfo colourise plugin.
Any developers out there want to knock one up?
Cheers
On Wed, 3 Aug 2016 15:18 Grant Boxer <boxerg at iinet.net.au> wrote:
> Is there a way to import MapInfo tab files into QGIS that preserves the
> patterns and colours?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160803/7b6620a0/attachment.html>
