[Qgis-user] MapInfo Attribures
DelazJ delazj at gmail.com
Thu Aug 4 05:35:23 PDT 2016
OpenWor might be available at http://piece-jointe-carto.
developpement-durable.gouv.fr/NAT002/QGIS/plugins/plugins.xml
2016-08-04 14:26 GMT+02:00 Chris Berens <chris at mapland.co.za>:
> Have a look at Nyall's answer to this from 2014:
> http://gis.stackexchange.com/questions/95085/qgis-analyst-
> create-finished-product-for-mapinfo-client
> Although I don't see OpenWor as a currently supported plugin.
> Chris Berens, GISc
> www.mapland.co.za
> +27 (0)82 567 9322
> On 4 August 2016 at 00:32, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> I understood from discussions with dms some time ago that at least for
>> simple styles, its theoretically possible as the underlying ogr library can
>> within limits see the details. Note lots of caveats, the file that keeps
>> this information, is like with esri, binary and proprietary.
>> For my end of exploration, this is a key step for qgis adoption, but I've
>> never been in a position to be able to get anything done about it.
>> I did at one point knock up some linux shell scripts to help with this.
>> It's not helped by the fact that mapinfo is not case sensitive, so to it
>> SHCC, SHCc, SHcc, Shcc, shcc, etc are all the same.
>> -ramon.
>> On 03/08/2016, at 17:52 , damien stephens wrote:
>> > If you have MapInfo wth discover, you can save the colour scheme for
>> each polygon as a new column in the tab file, then use that to colourise it
>> via the properties, styles menu in qgis.
>> > Failing that if you have a screen grab of the map/tab file you can
>> categorise the features   in qgis  by one of the other attributes then use
>> the colour dropper tool to select each of the colours. It can be very
>> laborious for a large and multicoloured map, but does get a very similar
>> output.
>> > Other than those options, I haven't seen a MapInfo colourise plugin.
>> > Any developers out there want to knock one up?
>> > Cheers
>> > On Wed, 3 Aug 2016 15:18 Grant Boxer <boxerg at iinet.net.au> wrote:
>> > Is there a way to import MapInfo tab files into QGIS that preserves the
>> patterns and colours?
>> > Grant Boxer
>> > Perth, Western Australia
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160804/11ad57d4/attachment.html>
