[Qgis-user] QGIS Crash Message
Martin Bain Martin.Bain at lismore.nsw.gov.au
Sun Aug 7 19:24:52 PDT 2016
I finally fixed my crash on every exit of QGIS 2.16.
Since my previous post my PC was replaced and I tried a fresh install of 2.16.1 but still got the crash every exit.
I ended up deleting the HKEY_CURRENT_USER\Software\QGIS branch from the registry.
Even though it was a fresh install of QGIS I think my user profile meant the old registry values followed me to my new computer.  This fixed the issue but was a bit heavy handed as I lost a lot of customs settings.  I exported the branch from the registry before I deleted it.  Merging it back into the registry caused the problem to reappear.  I tried deleting a few of the more complex looking sub branches but didn't find the registry value causing the crash.  Finally I deleted the whole HKEY_CURRENT_USER\Software\QGIS branch again, then started QGIS and with GIS running I merged the branch back  into the registry, I then exited QGIS without getting a crash!  I no longer get a crash on exit and I retained almost all of my settings - active plugins, recently used paths, expressions etc.  I lost a couple of thing that must be saved on exit such as the layout of the layers panel and the browser panel, but all good.
Cheers,
Martin
Sent: Friday, 22 July 2016 9:01 AM
To: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] QGIS Crash Message
I also get a crash every time exiting 2.16.  (On Windows 7 32 bit, OSGeo installer).
I deleted the .qgis2 folder from C:\Users\<username> but still got a crash on every exit, also tried running the OSGeo installer and selecting "Reinstall" for every item, currently using 2.14.3
Nice to know (sort of) that I'm not the only one.
Cheers,
Martin
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Grant Boxer
Sent: Thursday, 21 July 2016 5:40 PM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] QGIS Crash Message
Why do I get a crash - mini-dump message when exiting QGIS 2.16?
[cid:image001.png at 01D1F16B.067D88A0]
Grant Boxer
Perth, Western Australia
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160808/cb85eaee/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160808/cb85eaee/attachment.png>
