[Qgis-user] Labelling certain contours
Lester Anderson arctica1963 at gmail.com
Thu Aug 18 06:31:46 PDT 2016
Thanks Carlos, that worked fine
On 18 August 2016 at 14:11, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi Lester.
> I think you're close to do it. Try this label expression:
> case when "ELEV"%1000=0 then "ELEV" end
> Good luck
> Carlos
> 2016-08-18 7:49 GMT-05:00 Lester Anderson <arctica1963 at gmail.com>:
>> Hello,
>> Is there a simple way of labelling only certain contours rather than all?
>> I have set up bathymetry styling for thick contours (1000) and thin (100):
>> "ELEV" % 1000 = 0  (thick)
>> "ELEV" % 1000 <> 0 (thin)
>> I would like to label only the 1000 contours, i.e. conditional labelling.
>> Thanks
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
