[Qgis-user] drawing transport networks sharing lines
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Thu Aug 18 10:52:51 PDT 2016
Well, depending on how many classes you have for routes, you could make each type (class ) a differnt width, and stack the lines on top of each other with the widest one at the bottom of the stack.
If you don’t have vertical order control, you m,ight be able to get away with some level of opacity applied to each trail in order to see through to the next line type.
bobb
On Aug 18, 2016, at 12:20 PM, dave.potts at pinan.co.uk<mailto:dave.potts at pinan.co.uk> wrote:
I am trying to draw a transport network within qgis, sometimes  two network links share same path with the result the qigs draw each link on top of each other.
Is there anyway of getting qgis to draw the links next to each other?
For example with the tub network the district and circle line is drawn as two lines yellow and green next to each other when they share a common route.  Qgis would draw the green line on top of the yellow line
Dave
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Try a thing you haven’t done three times. Once, to get over the fear of doing it. Twice, to learn how to do it. And a third time, to figure out whether you like it or not.
—Virgil Garnett Thomson
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160818/792121aa/attachment.html>
