[Qgis-user] Qgis 2.16.1 crashes when opening a processing tool (Ubuntu)
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sat Aug 20 01:22:04 PDT 2016
Hi Stéphane,
did you already try to backup and remove your .qgis2 folder and QGIS2.conf
in .config ?
By this, you have real clean install. I also had several issues when
upgrading from 2.14 and this solved some.
If everything is fine afterwards, you could copy back your plugins
manually and restore saved connections etc. from the config file
Good luck
Bernd
Am 20.08.2016, 06:20 Uhr, schrieb Stéphane Henriod <s at henriod.info>:
> PS: additional info: I just downgraded Qgis to 2.14 LTS, and the
> processing tools seem to now work but i would be happy to use the >last
> version if possible :-)
> Any hint welcome!
> Stéphane
> Le samedi 20 août 2016, Stéphane Henriod <s at henriod.info> a écrit :
>> Hello
>> I have recently updated Qgis to 2.16.1 and Ubuntu to 16.04 LTS
>> Since then, whenever I try to open a processing tool from the
>> processing toolbox, Qgis crashes (no error message is shown).
>> Has this happened to anyone? Is there a known bug or something? As far
>> as I can tell, Qgis seems to be working properly >>otherwise.
>> Thanks a lot i advance!
>> Stéphane Henriod
>> CIM-Expert for GIS and Green Economy Statistics
>>>> Национальный статистический комитет Кыргызской Республики
>> Кыргыз Республикасынын Улуттук статистика комитети
>> National Statistical Committee of the Kyrgyz Republic
>>>> 374 Фрунзе ул. / Frunze str.
>> 720033 Бишкек / Bishkek
>>>> T   +996 778 46 99 02 (KG)
>> T   +49 176 280 11 050 (DE)
>> E    s at henriod.info
>> W   http://www.stat.kg
>> W3W: nightfall.into.bucket  //  запас.союз.дружный
> --Stéphane Henriod
> E    s at henriod.info
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160820/02fc94fa/attachment.html>
