[Qgis-user] Mapnik, QGIS and some other problems
Oliver Andjelkovic oliv14r at gmail.com
Sun Aug 21 10:22:52 PDT 2016
Hello,
I have problem or "lack of knowledge" related to the mapnik installation
over pip. I am using Win 8.1 and QGIS 2.14 and I have tried to install
mapnik package through OSGeo4W shell with simple command "pip install
mapnik". Well that went pretty well, but when I try to run script that call
mapnik from python commander in QGIS i get this message: "DLL load failed:
The specified module could not be found. See log for more details".
So, in log it stays:
 "Uncaught error while executing algorithm
File "C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/./python/plugins\processing\core\GeoAlgorithm.py",
line 203, in execute
self.processAlgorithm(progress)
2.14.5/apps/qgis-ltr/./python/plugins\processing\script\ScriptAlgorithm.py",
line 323, in processAlgorithm
exec((script), ns)
File "<string>", line 2, in <module>
File "C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/./python\qgis\utils.py", line
572, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "C:\mapnik-v2.2.0\python\2.7\site-packages\mapnik\__init__.py", line
69, in <module>
from _mapnik import *
572, in _import
ImportError: DLL load failed: The specified module could not be found."
Also, I always get Python error and processing error when QGIS starting.
2016-08-21T19:12:06 1 warning:C:\PROGRA~2\QGIS
2.14.5\apps\Python27\lib\pkgutil.py:186: ImportWarning: Not importing
directory 'C:\PROGRA~2\QGIS 2.14.5\apps\Python27\lib\site-packages\ndg':
missing __init__.py
file, filename, etc = imp.find_module(subname, path)
traceback: File "<string>", line 1, in <module>
306, in startPlugin
plugins[packageName] = package.classFactory(iface)
2.14.5/apps/qgis-ltr/./python/plugins\MetaSearch\__init__.py", line 29, in
classFactory
from MetaSearch.plugin import MetaSearchPlugin
572, in _import
2.14.5/apps/qgis-ltr/./python/plugins\MetaSearch\plugin.py", line 31, in
<module>
from MetaSearch.dialogs.maindialog import MetaSearchDialog
572, in _import
2.14.5/apps/qgis-ltr/./python/plugins\MetaSearch\dialogs\maindialog.py",
line 44, in <module>
from owslib.csw import CatalogueServiceWeb
572, in _import
File "C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/./python\owslib\csw.py", line
18, in <module>
from owslib.util import OrderedDict
572, in _import
File "C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/./python\owslib\util.py", line
13, in <module>
import pytz
572, in _import
File "C:\PROGRA~2\QGIS
2.14.5\apps\Python27\lib\site-packages\pytz-2014.2-py2.7.egg\pytz\__init__.py",
line 29, in <module>
from pkg_resources import resource_stream
572, in _import
2.14.5\apps\Python27\lib\site-packages\pkg_resources\__init__.py", line
2953, in <module>
@_call_aside
2939, in _call_aside
f(*args, **kwargs)
2981, in _initialize_master_working_set
dist.activate(replace=False)
2516, in activate
declare_namespace(pkg)
2098, in declare_namespace
_handle_ns(packageName, path_item)
2032, in _handle_ns
loader = importer.find_module(packageName)
directory 'c:\progra~2\qgis 2.14.5\apps\python27\lib\site-packages\ndg':
missing __init__.py
306, in startPlugin
classFactory
572, in _import
<module>
572, in _import
572, in _import
18, in <module>
572, in _import
13, in <module>
import pytz
572, in _import
572, in _import
2953, in <module>
@_call_aside
f(*args, **kwargs)
2513, in activate
fixup_namespace_packages(self.location)
2108, in fixup_namespace_packages
subpath = _handle_ns(package, path_item)
2032, in _handle_ns
and some plugins failed to load:
2016-08-21T19:11:58 0 Loaded Coordinate Capture (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/coordinatecaptureplugin.dll)
2016-08-21T19:11:58 0 Loaded Dxf2Shp Converter (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/dxf2shpconverterplugin.dll)
2016-08-21T19:11:58 0 Loaded eVis (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/evis.dll)
2016-08-21T19:11:58 0 Loaded Georeferencer GDAL (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/georefplugin.dll)
2016-08-21T19:11:58 1 Failed to load C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/globeplugin.dll (Reason: Cannot load library
C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/globeplugin.dll: The
specified module could not be found.)
2016-08-21T19:11:58 0 Loaded GPS Tools (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/gpsimporterplugin.dll)
2.14.5/apps/qgis-ltr/plugins/grassplugin7.dll (Reason: Cannot load library
C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/grassplugin7.dll: The
2.14.5/apps/qgis-ltr/plugins/grassprovider7.dll (Reason: Cannot load
library C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/grassprovider7.dll:
The specified module could not be found.)
2.14.5/apps/qgis-ltr/plugins/grassrasterprovider7.dll (Reason: Cannot load
2.14.5/apps/qgis-ltr/plugins/grassrasterprovider7.dll: The specified module
2016-08-21T19:11:58 0 Loaded Heatmap (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/heatmapplugin.dll)
2016-08-21T19:11:58 0 Loaded Interpolation plugin (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/interpolationplugin.dll)
2016-08-21T19:11:58 0 Loaded OfflineEditing (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/offlineeditingplugin.dll)
2016-08-21T19:11:58 0 Loaded Oracle Spatial GeoRaster (Path:
C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/oracleplugin.dll)
2016-08-21T19:11:58 0 Loaded Raster Terrain Analysis plugin (Path:
C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/rasterterrainplugin.dll)
2016-08-21T19:11:58 0 Loaded Road graph plugin (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/roadgraphplugin.dll)
2016-08-21T19:11:58 0 Loaded Spatial Query Plugin (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/spatialqueryplugin.dll)
2016-08-21T19:11:58 0 Loaded Topology Checker (Path: C:/PROGRA~2/QGIS
2.14.5/apps/qgis-ltr/plugins/topolplugin.dll)
2016-08-21T19:11:58 0 Loaded Zonal statistics plugin (Path:
C:/PROGRA~2/QGIS 2.14.5/apps/qgis-ltr/plugins/zonalstatisticsplugin.dll)
2016-08-21T19:11:58 0 Loaded DB Manager (package: db_manager)
2016-08-21T19:12:01 0 Loaded fTools (package: fTools)
2016-08-21T19:12:02 0 Loaded GdalTools (package: GdalTools)
2016-08-21T19:12:12 0 Loaded MetaSearch Catalogue Client (package:
MetaSearch)
2016-08-21T19:12:40 0 Loaded Processing (package: processing)
I hope that I'm not too boring with this questions, but I am sticked with
that for a quite time.
Best regards,
Oliver
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160821/0d0001e0/attachment.html>
