[Qgis-user] Problems with adding WFS layers
McDonaldR
McDonaldR at angus.gov.uk
Mon Aug 22 08:04:16 PDT 2016
Hi Chris,
I know we had to change fields called "location" and "name" to something else ("location_desc" and "xx_name") when loading data into PostgreSQL in our thirdparty web GIS system. This was then read by Geoserver and it complained about the reserved words. I'm not sure what version of Geoserver it is as it is managed by our thirdparty supplier.
Ross
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Chris Buckmaster
Sent: 22 August 2016 15:43
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Problems with adding WFS layers
I now believe this might be an issue with the use of 'location' as a column name - it loads ok using WFS 1.0.0 but 1.1.0 and 2.0.0 it does not load.
Did anything change in the specification between 1.0.0 and 1.1.0 to not allow these reserved word types as normal columns? Are there work arounds for this issue or would I need to rename any columns using 'location'? Is this a bug in v2.16 or just a change in the WFS standard?
Sent: 22 August 2016 14:51
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Problems with adding WFS layers
Hi
Not sure if this is a QGIS or Geoserver issue...
I have a WFS provided through Geoserver v2.5 - I have no issues adding layers from the WFS using QGIS v2.14, but in QGIS v2.16 I am encountering some problems with a selection of layers (within a specific Geoserver store).
The store which holds the layers that are not loading has the 'Expose primary keys' option ticked whereas others do not that are loading ok (I need to expose the primary keys), would this cause any problems? Below is the error I am getting when trying to access layers from this store...
2016-08-22T14:44:41 1 Server generated an exception in GetFeature response: java.lang.RuntimeException: Failed to get property: axisLabels
java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry
2016-08-22T14:44:41 1 Download of features for layer planning:tree_preservation_orders failed or partially failed: Server generated an exception in GetFeature response: java.lang.RuntimeException: Failed to get property: axisLabels
java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry. You may attempt reloading the layer with F5
Chris
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160822/ebed13a2/attachment.html>
