[Qgis-user] How to do square buffers around points (shapefile)
Tina Cormier
TinaACormier at gmail.com
Thu Aug 25 05:28:33 PDT 2016
Thumbs up to Eddison's reply - I just did this yesterday, and it works
beautifully! For those English speakers, the process is to:
1. Vector -> Geoprocessing -> Buffer, which will create your typical round
buffer.
2. Vector -> Research Tools -> Polygon from layer extent - will give you a
square. If you have multiple points, you'll want to check the option
"calculate extent for each feature separately."
Gracias!
Tina
2016-08-25 8:21 GMT-04:00 Eddison Araya <eddisonjose at gmail.com>:
> El 25 de agosto de 2016, 5:59, Manuel Spínola <mspinola10 at gmail.com>
> escribió:
>> Dear list members,
>> How can I do square buffers around points (shapefile)?
>> Best,
>> Manuel
>> *Manuel Spínola, Ph.D.*
>> Instituto Internacional en Conservación y Manejo de Vida Silvestre
>> Universidad Nacional
>> Apartado 1350-3000
>> Heredia
>> COSTA RICA
>> mspinola at una.cr <mspinola at una.ac.cr>
>> Teléfono: (506) 8706 - 4662
>> Personal website: Lobito de río
>> <https://sites.google.com/site/lobitoderio/>
>> Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hola Manuel, una solución es la siguiente:
> [image: Imágenes integradas 1]
> 1. Ir a Vector > Geoprocessing Tools > Buffer y generar los buffer
> normales con el radio que usted necesita definir
> 2. Luego crear una capa con la extensión del tema de buffer: Vector > Research
> Tools > Polygon from layer extent.
> Saludos
> Eddison
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160825/766dec1a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160825/766dec1a/attachment.png>
