[Qgis-user] QGIS 2.16 - Rule based labelling
Fuenfer-Koenigstein.Benjamin at swm.de Fuenfer-Koenigstein.Benjamin at swm.de
Tue Aug 30 01:03:24 PDT 2016
Hi Chris,
cannot confirm this behavior, my expressions are retained, both when I type them directly in the rule-list and when I type them in the "edit rule" window. I'm using 2.16.2. Can you give more details, e.g. what does your rule look like, what buttons do you use exactly, so I can try exactly the way you do? Did you try the "Test" button in edit rule window to find out if your expression works/makes sense?
Regards
Benjamin Fünfer-Königstein
S-IP-AN-TG Techn. Geschäftsfelder
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Chris Buckmaster
Gesendet: Freitag, 26. August 2016 13:28
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] QGIS 2.16 - Rule based labelling
Hi
I am using the rule based labelling in QGIS 2.16 and am noticing that when I go into a rule then choose the filter and put my expression in, when confirming this it does not retain my expression.
Is this a known issue or perhaps something wrong with the workflow I am using?
Thanks, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160830/1a3af7f8/attachment.html>
