[Qgis-user] QGIS 2.16 - Rule based labelling
Neumann, Andreas
a.neumann at carto.net
Tue Aug 30 03:58:07 PDT 2016
I just discovered this same problem when editing the source of an HTML
frame today. Newly introduced expressions aren't properly kept when
edited in the expression editor. Only when edited directly in the item
property.
Andreas
On 2016-08-30 10:58, Chris Buckmaster wrote:
> Hi Benjamin
> Yes the workarounds are fine for my uses and I will report this as a bug.
> Many thanks, Chris
> FROM: Fuenfer-Koenigstein.Benjamin at swm.de [mailto:Fuenfer-Koenigstein.Benjamin at swm.de]
> SENT: 30 August 2016 09:57
> TO: Chris Buckmaster; qgis-user at lists.osgeo.org
> SUBJECT: AW: QGIS 2.16 - Rule based labelling
> Hi Chris,
> yes, now I can confirm. I forgot to test the expression builder. The issue occurs, as you said, only when I change the rule in the 'expression string builder' window. A workaround might be to create the expression in 'expression string builder' window, copy it and paste it into the 'filter' text field which retains the text. Or you could change the expression in expression builder, OK, type a blank and delete it again in 'edit rule' window, then the expression is retained. Anyway, I think it would be good to report the bug on http://hub.qgis.org/issues.
> Regards
> Benjamin Fünfer-Königstein
> S-IP-AN-TG Techn. Geschäftsfelder
> VON: Chris Buckmaster [mailto:chris.buckmaster at runnymede.gov.uk]
> GESENDET: Dienstag, 30. August 2016 10:21
> AN: Fuenfer-Koenigstein.Benjamin S-IP-AN-TG; qgis-user at lists.osgeo.org
> BETREFF: RE: QGIS 2.16 - Rule based labelling
> Hi Benjamin
> My process is as follows…
> Using a point dataset from PostGIS, and the rule based labelling for Labels.
> My rule says "CLASSIFICA" = 'Woodland Or Forest' AND "FONTHEIGHT" = 'Small', with this I also have a scale range included.
> When I try to change this (for example to "FONTHEIGHT" = 'Medium'), I click on the browse button next to 'Test', I then manually alter the text within my expression from 'Small' to 'Medium'.
> I OK this - back at the 'Edit rule window', I do see that the text has changed to 'Medium', I then click OK but back at my rule based labelling screen the text still says 'Small'.
> If I decide to change the expression from the 'Edit rule' window and not open the expression, it does retain the change, so there looks to be an issue (from my set up anyway) where it is not storing any changes within the expression window.
> I am using QGIS 2.16.1.
> Thanks, Chris
> SENT: 30 August 2016 09:03
> Hi Chris,
> cannot confirm this behavior, my expressions are retained, both when I type them directly in the rule-list and when I type them in the "edit rule" window. I'm using 2.16.2. Can you give more details, e.g. what does your rule look like, what buttons do you use exactly, so I can try exactly the way you do? Did you try the "Test" button in edit rule window to find out if your expression works/makes sense?
> Regards
> VON: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] IM AUFTRAG VON Chris Buckmaster
> GESENDET: Freitag, 26. August 2016 13:28
> AN: qgis-user at lists.osgeo.org
> BETREFF: [Qgis-user] QGIS 2.16 - Rule based labelling
> Hi
> I am using the rule based labelling in QGIS 2.16 and am noticing that when I go into a rule then choose the filter and put my expression in, when confirming this it does not retain my expression.
> Is this a known issue or perhaps something wrong with the workflow I am using?
> Thanks, Chris
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160830/ac02e34f/attachment.html>
