[Qgis-user] Issue using time manager to show a line that changes in thickness over time
Steiginga, Luke Luke.Steiginga at nrc-cnrc.gc.ca
Tue Aug 30 05:49:46 PDT 2016
Hello,
I am running QGIS 2.8.9 and I am currently displaying a line that varies in thickness along its length. The entire line is made up of many smaller lines each having a different thickness. It was added using a csv file using a WKT column that contained the information necessary to make the lines. These smaller lines all have different thicknesses corresponding to a numeric value that had been previously calculated in the csv file.
This all works as it should.
My problem is that I now want to have this change at different times when I use the time manager. In other words, I want the thickness of each line to change from one week to another. The csv file has a start time and an end time as shown below in columns "Timestamp", and "End Time". The first column contains the numbers that I want to indicate the thickness.
Expected             x                              y                              WKT        Timestamp                End Time
0.0001109            -1247455.1          1419954.2            LineString(-1247455.1 1419954.2, -1247455.2 1419954.3)                 4/1/2016 6:00        4/8/2016 6:00
0.004392              -1247455.2          1419954.3            LineString(-1247455.2 1419954.3, -1247571 1419993)                        4/1/2016 6:00        4/8/2016 6:00
After 4/8/2016 6:00 there are different values for the thickness of the lines that I want displayed. These are lower down in the same file. I show a sample of what would be in the csv file at this point below:
0.002145              -1247455.1          1419954.2            LineString(-1247455.1 1419954.2, -1247455.2 1419954.3)                 4/8/2016 6:00        4/15/2016 6:00
0.003391              -1247455.2          1419954.3            LineString(-1247455.2 1419954.3, -1247571 1419993)                        4/8/2016 6:00        4/15/2016 6:00
Each new week, all columns except the first column remain exactly the same, because all I want to do is have the thickness of the line segments change with time.
I tried to do this by opening the time manager and adding a layer. I set the start time as the "Timestamp" column and the end time as the "End Time" column. I am trying to make QGIS display one thickness for the first week and then show the second thickness for the second week and so on.
I would have expected this to work, but instead the layer doesn't show up on the map at all after doing this.
Could someone please tell me what I am doing wrong or how I could possibly resolve this issue?
Thanks,
Luke
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160830/d296895a/attachment.html>
