[Qgis-user] .GDB to .KML/.KMZ?
Stefan Keller sfkeller at gmail.com
Tue Aug 30 13:10:52 PDT 2016
If you mean ESRI File Geodatabase (FileGDB) then you can also use my
free online web app:
https://geoconverter.hsr.ch/ (pls. use responsibly :-))
:Stefan
2016-08-30 21:48 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 31 Aug 2016 04:57, "Simon Minching" <sminching at gmail.com> wrote:
>> Hi everyone,
>> Can QGIS import a gdb file and allow a user to transform it to kml/kmz for
>> export and re-use? I didn't see anything to this end within the user
>> documentation
> Definitely - I do this all the time! Just open the gdb data source (eg drag
> and drop it in QGIS), then right click the layer and select "save as". You
> can then change the output format from that dialog to KML or kmz.
> Nyall
>> Excited to dive in here!
>> Thanks in advance,
>> Simon
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
