[Qgis-user] .GDB to .KML/.KMZ?
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Tue Aug 30 12:44:26 PDT 2016
Hi Simon,
Try gpsbabel if your gdb is a Garmin GPS file (I guess it is), to convert it to GPX, which you can open in QGIS like any other vector data
(If your gdb is an ESRI File Geodatabase you can open it in QGIS directly if you have the gdal-plugin installed).
After opening the file in QGIS go on “Save as” and choose kmz /kml as output format.
Hope that helps!
Cheers
Stefan
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Simon Minching
Sent: 30. august 2016 20:57
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] .GDB to .KML/.KMZ?
Hi everyone,
Can QGIS import a gdb file and allow a user to transform it to kml/kmz for export and re-use? I didn't see anything to this end within the user documentation.
Excited to dive in here!
Thanks in advance,
Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160830/40ba602a/attachment.html>
